x850xt OEM 111.00 dollar!
NewMonster
i jus ordered an OEM saphhire x850xt!!! for 111.00 US dollar grand total. is that a go0d deal?
and why is a x800xtPE superior than x850xt?
That's a good deal, yes.
The X850XT PE just has slightly higher core and memory clocks.
I have the x850xt I got for $90 ..the x850xt is superior to the x800xt pe the 850 uses a different core I think the 850 has 16 pipielines and the 800 only has 12..
Who said anything about an X800XT PE?
EDIT: Whoops, nvm. But the x850xt pe and x800xt pe arent all that different. Just clock them the same and you have yourself two cards that perform about the same.
Noob101....
The X850 does in fact use a different core than the X800 (R480 instead of the R423). However, they both have exactly the same stats, if clocked at the same speeds. They both have 16 pixelpipelines, etc.
http://www.gpureview.com/show_cards.php?card1=55&card2=41#
to see that a x800xt PE has more memory bandwith than the x850xt is pretty weird. and the x800xt PE is superior as i see the comparason but not by much... jus a tiny bit but still weird.
im thinking of getting one of those, what are the dimensions of it because i need to know if it can fit in my case? thanks
Noob101....
uhh... jus wanted to say the link is a comparason of x850xt vs x800xt....
i wonder y x800xtPE has higher score in benchmark and higher spec than x850xt http://www.gpureview.com/show_cards.php?card1=55&card2=309
uhhh... i dont kno, i dont have my ruler but i can tell u that it fits my emachine mid tower 2005 T series
I meant to compare those two cards. The X850XT will perform better than the X800XT PE because of the higher clocks.
Oops..
Actually, they would perform almost the same, but the X800XT PE has a 560Mhz memory clock, and the X850XT only has a 540Mhz clock. However, the X850XT can probably be overclocked more than the X800XT PE can.
u got urs for 90 dollars..... hows the condition? is it used? new? owm? refurb? etc...?
mine was flawless! OEM i can still smell the freshness of it! no dirt no nuttin on the see through plastic-cover exhaust. original sapphire box everything included. everything is flawlessly!
