Which card/
Your video card probably won't last very long seeing how the new games are starting to use Direct X 10 already. I recommend getting an nVidia 7800 GTX 512 MB or higher for pci-express x 16 slot on your motherboard. If you don't have a pci-e slot, you should really consider getting a new motherboard that supports it.
I only have about 200-250$ to spend on the video card.
The 7800GTX isnt a DX10 card...
