Memory/Mobo compatibility
compnub2
Motherboard - GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813128012 ($135)
Patriot 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory Model PDC22G5300LLK
http://www.newegg.com/Product/Product.asp?item=N82E16820220095 ($219)
"Notice: Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets."
Memory is DDR2 667 and 4-4-4 timing, volts are the same. Will this boot up the first time and will I need to change any BIOS settings?
Scrap that "rule". Just because they "aren't approved" doesn't mean they won't work. Your DDR2 667 memory is fine, and should overclock pretty good.
