my computer Hang
jariknet
Do everyone know about this problem. My computer hang in the middle of run?! Could anyone give an suggestion?!
thnk's:D
Hmm, when start up. I work on freebsd. So, when it start to check file system (on start up) it going to stop.
well, im going to take a stab at the 1% then.
by 'hang' do you mean 'freeze'? there is a difference...
if its freezing, then chances are that your overheating.. check all your fans for dust and that they are all working. if it is actually hanging it means there is a programming error or a hardware conflict.
in case you didnt know, a system hang is where the pc doesnt know what to do so it simply stops, it is sometimes responsive, sometimes not.
try reinstalling windows.
A freeze is where no buttons work nothin is responsive, a hang is where things still move n sometimes work for example you know the windows loading screen how it slides across. if it just keeps sliding and sliding and sliding and sliding, thats a hang
