jasonz New Member Dec 10, 2006 #1 I run the avg free spyware. It used to always be running, but now the active shield isnt on anymore. It just turned off and says n/a. I see that you have to purchase it for the shield to be on, but why did it used to be on?
Buzz1927 Digaredd Dec 10, 2006 #2 You get the full version for 30 days, then some functions (like the active shield) are turned off and you just have the scanner.
jasonz New Member Dec 12, 2006 #7 im not using the avg AV, just the antispyware. Does Avast have an antispyware app.?
jasonz New Member Dec 13, 2006 #9 Arawn said: lol, then use SpyBot ! Click to expand... Got it already. I think im doing ok on security.
