How do you tell if an lcd monitor has a dead pixle or not? is it clearly visible? or do you need some sort of program to tell you if it has any?
A dead pixel on an lcd will stand out after a period of time when it remains a constant black spot while other colors are seen everywhere else. A single pixel will be a small square area not much over the size of the head of a pencil. That's a steady dead area of space on the monitor itself with no software designed for this. Manufacturers have their own diagnostic tools to see if a monitor is functional but not for dead pixels on the display itself.
If you can't see a deadpixel there probably isn't one...And if there is one and you can't see it, well consider yourself lucky![]()
[-0MEGA-];519651 said:They can be black, or red, or blue, or yellow. They have some programs out there which show a single color on the entire monitor, making it easier for dead pixels to appear, and they have the option to try and fix the dead pixel.
thanks for that program, i'm gonna bookmark that incase i ever come across a bad display.
i've freaked out a few times before, only to find that my 'dead pixel' was nothing more than a flake of dust![]()
