New Comp.. IE7
Warriorhazzard
I would like to install IE7 on my new comp. But how do I go about doing this? Do I burn the file from my laptop to a disk then just pop it in?
How do I do that?
I dont need IE or FF for that right?
EDIT: I NEED to get the actual IE7 on my new comp.
Im using Windows XP Media Center.
I looked in Program Files and there was a folder with the name "internet explorer" but the only file in there was "connection wizard" and inside of that was nothing.
I looked from start and ofcourse there was nothing.
There is an icon that says Internet Explorer but I click it and a window appears with a list to choose which prog. to open it with. If I click cancel it says that the Item is unavailable.
You're on the internet right now??? Oh well, no biggie, try this, go into a folder(My Computer, My Documents, something like that) and type in www.microsoft.com, after that, than in top downloads, it should say Internet Explorer 7, try that, if your computer's not genuine PM me or e-mail me at [email protected].
