New 8800GTX
CmoAMD
Sorry ive been busy with my new job and havent seen computer stuff in a minute. Whats this new card? What did I hear about it needing 2 slots? Can you put 2 of them? Is it a 2 in 1 like the 7950s? 2 cards meaning quad sli? Thanks
2 of the 16x or what? Can you dual 8800 with the new asus crossfire mb?
The 8800 only takes up one physical slot, but the cooler takes up an expansion slot (still uses only one physical slot on the motherboard).
Yes you can use two of them in SLI.
What do you mean 2 of the x16? If you have a motherboard that supports dual x16 slots while in SLI mode, then yes you can.
It's called the Asus Crossfire Motherboard, not the Asus SLI Motherboard, so no.
Thats what I put, asus crossfire mb/motherboard. Just wanted to know if it was blocking the other x16 slot, which is needed to run another card. Is 2 x 8800 better than 2 x 7950?
Oh I see what you mean. It depends on the way the motherboard is designed, mine for instance has a slot between each PCI-E x16 slot, so I can use multiple double-wide video cards.
And yes, 2x 8800's are better.
you were right the first time.... he's talking about a crossfire motherboard..
Crossfire motherboards are AIT multi GPU only, look into an nVidia chipset for SLI
I dont think hes talking about using SLI on a crossfire motherboard, because I already said that wasnt possible. I think hes asking if having two 8800's would fit on a motherboard such as the Asus Crossfire.
oh, so not talking about working, but fitting physically?
Here is a picture I will show people when they ask why the 8800 takes 2 slots:
The extra slot is due to the cooler on the card which comes standard. SLI boards should come with room for this in between cards in SLI.
Guys its called the ASUS Crosshair not Crossfire. The ASUS Crosshair is 590SLI. And yes they will fit. Question is will the processor you currently have be able to support both or atleast 1 of them.
Here is my ASUS Crosshair board. The blue slots are the PCI-E 16 slots for graphics as you can see theirs plenty of space.
what do you mean with Crosshair? If its an SLI chipset, its SLI, no? only that motherboards name is asus crosshair.. but thats completely off topic tough :o ( i think )
from what I gathered everyone one was confusing the ASUS motherboard name Crosshair with crossfire which I think they thought it wasnt SLI compatible when in reality it is. Since everyone was confused on the name they thought the ASUS crossfire was not SLI only crossfire capable.
So I was just hopefully correcting the terms.
naw, he said the new ASUS Crossfire, not Crosshair ;)
I understand he said ASUS crossfire but I dont see any motherboard from ASUS called the Crossfire. I see a few that are crossfire enabled but not as the model name, thats why I said he most likely meant the Crosshair as I can see why someone might get the names confused.
OMG! Look what I started :D. Im sorry, I meant CROSSHAIR Motherboard obviously, like pumaking stated theres no ASUS Crossfire motherboard. My mistake.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131593
Thats the motherboard im talking about, I was concerned if you get a 8800 card if it would block the other x16 slot needed to run 2 of them in SLI. Which I guess by the above posts wont be a problem.
As far as the CPU to support 1 or 2 of them, I was going with the 5200 X2, will that be enough?
This is the PSU http://www.newegg.com/Product/Product.asp?Item=N82E16817153036
and im not sure which case to get,
http://www.newegg.com/Product/Product.asp?Item=N82E16811133032
http://www.newegg.com/Product/Product.asp?Item=N82E16811133021
Hope this sums it up. Sorry for the typo
You can fit two 8800's in there, because there no wider then the current dual-slot cards. And that PSU is deffinetly strong enough for an 8800GTX, but most likely not two because its only 48A, you may want to look for a slightly higher one.
Just make sure there is enough room length wide for the cards, because they are insanely long.
