External Hard drive
Shane
Super Moderator
Hi,
Anyone know where i can get a quite cheap external Hard drive from in the uk?
I know i can get a hard drive from anywhere but they are all like 250Gb and 500Gb max.
I dont need that much space so it would be a waste of money buying that much.
All i need is about a 100Gb hard drive,But i cant find any less than 250Gb.
I want it external so i can transfer stuff to other pcs.
I dont realy a price limit because i will decide upon the price if you nkow what i mean.
Thanks.
EDIT:i found one here...
http://www.pcworld.co.uk/martprd/st...null&sm=null&tm=null&sku=373372&category_oid=
Its still like 60Gb bigger than i need but i cant find any smaller.
Is that a good one?
i bought 200gb external hd from ebay seller envizage2000 was about £70 transferred all my music to it,the only thing is,if it is switched off for a length of time will i lose the data insideor does it stay there regardless?
Well that doesnt sound too good:D You transfered music files to it and then they dissapeared?
Maybe its faulty?
Anyway i also think you got ripped of.... £70 second hand is a rip off.
You can get a brand new 320Gb Maxtor external hard drive for £69.99 here..
http://www.currys.co.uk/martprd/sto...null&sm=null&tm=null&sku=133685&category_oid=
Actualy i might get that myself.
on ebay, a 100GB external is $80-100 US, while a 300GB can be had for $115 US.
I'm sure you could find SOME use for the extra space.
