diduknowthat
formerly liuliuboy
So I'm trying to mimic the blur/slowmo affect in FEAR, but on a smaller scale. I'm doing a spanish video project, I need about 4 or 5 seconds of slown down, blurred video with the bullet trail affect. The only way I can do it is probably with adobe photoshop cs2, as i dont have any other programs. So bear with me.
What I'm thinking is, Take the picture, first draw a grey line from my gun tip to the place where the bullet strikes, then use the smudge tool and rub it around a bit so its a squigly line. THe blurring of the picture will be done in premier pro with the radial blur. But the grey drawing lines looks kinda wierd. ANyone else have a better idea?
Thanks in advance
Thanks in advance
		 WOW! I bet you wish you had adobe after affects!
