Pentium D vs. E6600
murdock22
Right now I have a Pentium D 3hz, as I built this computer before the Core 2 Duo's came out. I was wondering if I upgraded to an E6600 (yes my MoBo will work with it) would there be much difference? I game almost everyday (Battlefield 2) and do some other thing such as back-up movies and burn them. would it be worth spending the cash and upgrading to it or would there not a big enough difference? Also does the E6600 run cooler or hoter then an pentium D?
The difference, especially in games, is pretty dramatic when switching to a Core 2 Duo. Although I would buy a better video card before buying a newer processor.
There wouldn't be a huge difference in gaming, but CD/DVD burning times would go down a bit. The E6600 runs cooler than the PD. Honestly, I wouldn't recommend it. Your processor is running fine right now, I'd wait a little until you really have a need to upgrade it, and prices are cheaper.
CD/DVD burning would go quicker? How can a faster processor make the drive record to the media faster? I think you mean if you rip, encode, or decode CD's and DVD's.
you said that i should upgrade my videocard before upgrading my processor, i was just wondering how would upgrading it affect anything as i can play all my game on high
Then Why The Hell Do You Want To Upgrade!!!!!!!!!!
Exactly, if you can play games on high now, why do you want to upgrade?
I said you should upgrade your video card because I was assuming you wanted to play the newer games on high to highest settings. I know you can play some new games on high, but not highest.
So does that mena that a 7600 GT is not very good for high-end gaming???
