That is external data transfer. Like i said, the 3GB/s refers to internal data transfer, that is to say that data never went through the SATA cable, but instead was either deleted or copy and pasted, etc.
OMG! Not an external HDD! I think you may be the one who must stop the crack.I mean external as info from internal HDD to MOBO to RAM. Internal as HDD to or erase on the same HDD.
Well I did some benchmarks with my 3GB/s on "top performance" set in BIOS and I got a little over 3GB/s on the test. Without it on I got 750MB/s. I believe it refers to the data transfer on on the hard drive itself (ex: deleting a 3GB file) but that is internal transfer which is what the 3GB/s means for, if you want it to go to something else it must go through the SATA wire which is external transfer and will never get that hi.
Just cuz you dont understand English doesn't mean you can try and falsify my words by saying that I mean something that you know I didn't.If I wanted to say external HDD then I would have. you know that. Weather you want to say read or write I dont care, and how about you tell us then what they mean 3GB/s means or are all these HDD makers making false comments as you say over and over again?
