what to get 7900GS or the 7950GT???
The_Beast
How good is the EVGA 7900GS??? Newegg doesn't have the 7950gt I want and there are no 7900GT left. will it be good enough to play most games at high setting at high res with good FPS???
Or should I just suck it up and get the 7950GT that is $270???
BTW i will be using the EVGA step-up program to get a 8800GTS/GTX in the next three months
ckfordy
banned
If you want to spend that much money i would get the 7950GT it is better then the 7900GS. Otherwise the 7900GS should still be able to play games at high res with reasonabyl good FPS.
MatrixEVO
If your using the step-up in a few months you should just get the 7900GS because that is a very nice card as of now and will play alot of games maxed out. Just hold out for a few months with it and you will be saving some money for the time being.
The_Beast
It HAS to be eVGA, and the 7950GT is only 256Mb i would want at least 512 is i got a 7950GT
yeah i wish they had a 7900GT that would be just right
i still dont know what to get
