Advise/Comment Wanted plz...
LazYboI
Hi guys, im trying to build a computer for gaming but had a budget for around $500. This is what i came up with. Please give any comments any advise. Thank you. ^__^
Tower
http://www.newegg.com/Product/Product.asp?item=N82E16811208008
HDD
http://www.newegg.com/Product/Product.asp?item=N82E16822144415
MOBO
http://www.newegg.com/Product/Product.asp?item=N82E16813138264
VID
http://www.newegg.com/Product/Product.asp?item=N82E16814143049
SOUND
http://www.newegg.com/Product/Product.asp?item=N82E16829102002
RAM
http://www.newegg.com/Product/Product.asp?item=N82E16820145440
Processor
http://www.newegg.com/Product/Product.asp?item=N82E16819103528
or
http://www.newegg.com/Product/Product.asp?item=N82E16819103588R
leaning towards the dual core what ya think??
CPU COoling
http://www.newegg.com/Product/Product.asp?item=N82E16835185125
not even sure if i need this...i am new to this...>_<
CPU Thermal paste
http://www.newegg.com/Product/Product.asp?item=N82E16835100007
That's it...total comes out to around $700 but after MIR it'll be around $600. So i know it's $100 over my budget but that's the best i can come up with. Any help? Anything im missing to build and run the computer? Thnx guys for any input. ^.^
Why are you building socket 939?
For that budget, you could probably get a C2D. It might be a little stretch, but I think you could do it.
You had to say that again?
The C2D build is pretty good, but I would strongly recommend a different motherboard.
thnx guys for the inputs...i am new to this so didn't really know the difference between amd and c2d...thnx for the advise. Guess i got more research to do...^.^
this build is pretty decent u can always change the case and gpu i picked out
Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
191.00
GIGABYTE GA-945PL-S3 Socket T (LGA 775) Intel 945PL Express ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16813128025
75.99
CORSAIR ValueSelect 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820145526
105.99
ASUS EAX1300PRO/TD/256M Radeon X1300PRO 128-bit GDDR2 PCI Express x16 Video Card - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16814121550
68.99
Thermaltake TR2 W0070RUC ATX 430W Power Supply 115/230 V - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
39.99
Western Digital Caviar SE WD800JD 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16822135106
43.99
SONY Black 52X CD-ROM IDE CD-ROM Drive Model CDU5225 - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16827101134
13.99
RAIDMAX xB ATX-528B Black SECC Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16811156053
19.99
total
559.93
Tower
HDD
MOBO
VID
SOUND
RAM
Processor
or
CPU COoling
CPU Thermal paste
The CPU Cooling, Thermal paste and Sound Card are not required. I would purchase a separate PSU (NOT the Thermaltake unit that's been recommended), however, or get a case that includes a better one, such as the Athenatech A416BS.400. You also haven't included an optical drive.
A few suggestions:
75.99
GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16813128017
124.99
I know it costs more, but it's worth it. One of the best budget C2D mobos you'll find.
68.99
The 7600GT he had originally is a MUCH better video card, for only $10 more.
39.99
XClio 450BL ATX 450W Power Supply 115/230 V UL, CUL, TUV, CB - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
39.99
A MUCH better PSU. If budget is a real concern, this Hipro 400W will also suffice (still MUCH better than the Thermaltake), or you can get the Athenatech case I mentioned earlier that includes a good PSU.
13.99
A DVD-RW drive isn't that much more, if you need an optical
