Wassa good program?
g4m3rof1337
An Anti virus program.
That if it detects or finds a threat, it deletes it.
Iam currently using AVG and i dont think its working.
And maybe a good firewall and spyware protection.
iam not keen on buying it.
thank you
Thanks bobo.
i currently also use adaware SE personal , so thats a good spyware remover?
So i prolly wont need a spyware.
ZoneAlarm, isnt that like everything? can i use adaware and ZA?
thanks
I agree with that entire list although i havent run zonealarm in like 2 years just been using the windows one and been fine
I haven't run a firewall in years either, it's really not that important. Avast has very good on-access protection, and Windows will keep out the hackers well enough.
i dont use virus checkers, they slow down the pc and can stop internet from working with their stupid firewalls.
i use windows firewall and my netgear firewall thats on my router.
You contradict yourself 3 times here.
1. Virus scanners do not have firewalls
2. Virus scanners do not slow down the computer at all, except when you are running a test (which could be at 3 am)
3. Virus scanners cannot stop internet from working
4. Antivirus software is more important than a firewall.
There is always a "what if"... Just don't go to pron or illegal websites where these things breed at. And in the FREAK incident where you get a virus from AIM occurs, use google.
Why dont you think AVG is working? it works fine for me... just because it doesnt detect things doesnt mean it isnt working, it means you have no viruses.
