Asus P5B Deluxe or Gigabyte DS3??
I'd say the DS3. I've had both Gigabyte and Asus motherboards, and I find the Gigabytes to be better quality and easier to use.
was going to by Asus P5B Deluxe, but all of the sudden I've been hearing alot about Gigabyte DS3. I plan to OC a little to make my e6600 to the speed of e6700, thats 2.4ghz to 2.66ghz.
WHich would you perfer?
DS3
http://www.newegg.com/Product/Product.asp?Item=N82E16813128012
or
P5B Deluxe
http://www.newegg.com/Product/Product.asp?Item=N82E16813131045
If you are just planning to overclock to 2.66, just about any motherboard will do the job. With either of the motherboards you posted, overclocking will more likely be CPU limited then motherboard limited, because at 450FSB, your processor will be running at 4.05Ghz :).
