Ughhhhh
yea thats what i thought, but i tried and it dosent work. the button that says PrtScn below it it says SysRq and then below that it says Insert so im wondering if i have to hold Ctl or shift or something...
What program are you trying to paste it into? The way I do it is Print Screen<paint.net<edit paste
well i tried pasting into everything, paint, word etc... i did it on a school comp but i cant do it now. i have a wireless keyboard and mouse and im wondering if it dosent support it or something? i tried opening the set-up program but it dosent list "print screen" this is soo strange!!!!!
this is a paint company????? not a program...
Are you RIGHT clicking and pasting it or are you going into edit and trying to paste it?
I know if I try and right click the paste option is not there, I have to go to edit and paste it that way
nope nuthing worked. i tried pressing the button then opening paint, then right clicking (option not available), ctl + V, nuting happened, i tried to restore my wireless keyboard settings, nuthing changed, i installed fraps, assigned the key F10, pressed it, went to where it supposed to save it, empty. uhh mabye its in the controll panel????
