is this good?
hard to say, never seen it before. I personally use CCleaner, the first time you run it, uncheck or check the things you want it to delete, after that you just run it.. does real good. :)
jbrown456 you can put you sig into your sig without a link go to your photo bucket album and chose the img code to insert it into your sig :D :D :D
A. What does this have to do with this thread
B. You can't do that. If you don't beleive me, try it.
I have both and I prefer CCleaner. Windowwasher is a bit of a resource hog IMO.
How is it a resource hog? It only uses resources when you use it for a whole 10 seconds and then you shut it down. I use them both myself for different reasons, ccleaner will also clean your registry but windows washer will clean all your yahoo IM files that CCleaner will leave behind and it cleans other files like outlook express files, printer files that Ccleaner will also leave behind. You can also wash your free space with WW and it will write random 0's and 1's over deleted files making your data much harder to retrieve. Ccleaner is much faster though for a quick delete of unwanted files. Bottom line is though they are both great products and they both serve a purpose on my PC
