Logitech mX 518
I used to have one, much better then the G5 in my opinion.
And you dont need the software, the buttons are detected right away.
how do i install the driver without freezing my computer
It seems logitech sent out a bunch of badly burned driver disks because my g7 disk also frose my pc. I just downloaded the driver off of logitech's website, and everything went smoothly.
As for a mouse mat, you shouldnt really need one considering its an optical mouse. :P
Same thing happened with installing my g15 but solved it with hooking another keyborad in, hooked another mouse it did the same thing.
thanks
i got the mx 518 mouse u could try downloading driver off the site? i have a razer exact mat takes up like my whole desk (my desk is small)
Lunch
