Blue screen memory problem
Jsousa373
Hey all, i just built a new pc, and i have been having some problems. I installed 2gb of ram, and my comp keeps freezing/getting blue screen. The blue screen says "blah blah blah" begining physical dump of memory. I have had this problem with ram in the past, and i have done all the steps to see if the ram is bad. Is there a program that can search for ram or memory errors? If you know of one please let me know.
thanks
If you can get to windows theres an installer option for that. Otherwise get the ISO zip file and burn that to a cd from another computer. It makes a bootable CD so you can test your RAM.
