new psu.
Unless it's not supplying enough power you don't need a new one.
Save your money for when it dies on you which could be in a good few years.
The new card I have but isn't installed yet needs 450w to run and higher I have 320 or 350w.
A card that needs 450w? Where did you get that information from?
I assume you mean when you total everything up?
Not true. It is possible for a cheap power supply to mess up a computer or it's components. That's why I'm running a pretty expensive 550w PSU in a system that is calculated to only need about 300w :P
Aside from wattage, you need a good amount of amps on the 12v rail(s). If you do wish to upgrade, the Rosewill is a better PSU with duel rail and all.
You'll need to upgrade. Of the two, the Rosewill is the better PSU as TOO said. Could you stretch another $10? The Enhance 5150GH is available from www.ewiz.com for $69, and is a much better PSU.
Ya it wouldn't be a problem... aw to bad it doesn't have an led light in it like the other.I love the lights inside psu's/
another thing, how much better is it then the rosewill?
