AGP and PCI-E Motherboards?
nffc10
Well, motherboards arn't strong points in my computer knowledge.:D Are there any such motherboards?;)
ASRock makes alot of those types of motherboards.
I used to use one for LGA775 CPU's that have an AGP+PCI-E slot, and DDR+DDR2.
Yea it seems like I saw a Asrock 939 board with a slot to mount a Asrock adapter for a AM2 processor with DDR and DDR2 slots
All the ones they make are crap. I would never buy one. Your either PCI-Ex or AGP, both is just stupid.
As long as you dont want to overclock (much), there fine. I used one and it actually performed very well.
True it doesnt perform as well as an Intel or nVidia based board, for the price and features it offers, it's a great choice for some.
Still wouldnt trust one, having 2 different interfaces like that on there could cause some problems......and lead to instability issues.
those boards only provide the pci-e slot with 4x bandwidth instead of 16x
dont buy one at all
dont buy one at all
It has it's downfalls, but if your a person who is extremely poor, and have a Pentium 4 socket 478, AGP card, DDR ram, etc, and you want to get a Core 2 Duo, this way you can use your existing AGP card and DDR RAM without needing to buy new stuff right away.
dont buy one at all
ASRock's mobo for S939 and AM2 which has DDR, DDR2, AGP8X and PCI-E 16x, has the AGP and PCI-E at the full speed. AGP and PCI-E versions of the same card perform the same on that motherboard.
