$600 budget build
lunchboxx
hey guys i need you guys to make up a $600 pc setup its gona be used for minor gaming internet and other basic stuff i would prefer core duo but who knows all i need is the tower, not the os or monitor or anything just the tower it can go a lil over 600 if it needs to no need to have more then 120gb space and needs 1gb =] so you guys work your magic:)
Thanks
Lunch
and no sound card is needed=]
umm...one thing: if he only has $600 to spend then why get a CPU that costs more the 1/3? just get the e6300 instead of the e6400...
and please spend the saved money on a better GPU...x1300 is not very good.
and...you know what...hey im just gonna make my own list :D
Sry bout that i was on my way out and just did a quick build.
and for the cpu for some weird reason i couldn't find the 6300. :confused:
the build lb562high put together looks good..:)
aight thx guys ill prolly get the build lb had :) nver thought i could fit a 7600gt in the budget but like i said you guys are magic :P
Thanks
Lunch
