Is this a good Rig?
Yeah, all looks good, but why do you need two power supplys?
At a glance I cant see any conflicts, just go over it again yourself and you should be good to go.
HTH
Adam
HTH
Adam
well the psu that comes with the case is "crap" according to other peoples reviews.
Oh ok fair enough lol. It doesnt seem to good from the reviews I must agree. The PSU you have chosen is very good on the other hand.
Adam
Yeah i wouldnt use the one you get with the case as usualy there no good.
If you read the Cons of that case on newegg you see that someone mentions....
5 min after hooking the computer up the power supply dies!
The build looks good however.
