Computer restarted
Shane
Super Moderator
Hey guys,
What would cause a computer to suddenly restart?
I was playing warrock and also was listening to Itunes radio just and was playing for about 15 minuites and my computer just restarted:confused:
It doesnt do this just playing warrock alone so whats up you think?
Accediently pushed the reset button or a problem based around the reset button must likely.
i appreciate you replying to my post but i highly doubt that was the cause of my sudden restart.:D
I sit nowhere near the base of my computer so there is no way of me been able to press the reset botton without having to stand up and press it.
It hasnt done it since but im still concearned to why it done this?
it may be your psu not supplying enough juice or video/cpu overheating.
hmm,
Well my Psu is a 400W but a cheap one so you could be right:eek:
However do you think that my system is even powerfull enough to require a 400w psu?
Im gonna try running warrock & itunes together again and see if i get a restart.
Its fine if i just play warrock alone.
It
I meant where the reset button plugs in to the motherboard, but it is true that it's ulikely.
have you done any anti virus/spyware scans recently? it could just be an annoying virus.
or the only othr thing i would think of is that your computer is over heating :confused:
