ram suggestion?
You can change the voltage in the BIOS so as long as you can POST (which is the case with most, if not all RAM that requires overvolting) you can change the voltage to what it should be. Usually you'll find that RAM like that is set up so it runs slower until you go into the BIOS and set it up properly.
