is there a site that shows up coming phone releases for tmobile?
blahxyzblah
id like to know what new phones tmobile will come out with and when.
thanks!
edit: another question... i want to get the razr v3t from tmobile, and i was wondering if i could just buy the phone from ebay, and when i receive it, just insert my sim card from my old phone into the new phone i just purchased.
when i buy the phone and just insert my sim card, do i have to inform tmobile about my phone switch? or... do i just not tell them anything?
also, arent all the phones on ebay locked or unlocked, so i can just buy any v3t and just use my old tmobile sim card?
and, so if a gsm phone is unlocked ill be able to use my tmobile sim card on it, even if tmobile doesnt carry it and another company does? like the v3i for cingular?
1. You dont have to tell them, but it always helps. Just call or do it online, they dont care if you bought if off eBay.
2. All phones in the world are unlocked or locked. You can buy any unlocked GSM Razr or any locked T-Mobile rzr to put ur SIM card in.
3. yes, usually
thanks!
Heres my answers to those questions...
1. You should probably contact T-Mobile (*******T-Mobile.com*******) themselves and see.
2. I was thinking of buying the T-Mobile V3 Razr (To-Go, Prepaid :D !), too (:D :D :D !!!!!!!).
I think you should just buy it from T-Moble, the Manufactures.
I think it's safer that way.
