You can uninstall IE7 in Add/Remove programs, then you'll be back to using IE6 again, then reinstall at a later date.![]()
Liking the website..........Hillary Duff, love her!![]()
No problem![]()
Worth mentioning the Virtual PC to do what she wanted.
No disrespect but, have you read the thread?
That's why i told her to uninstall IE7, then install it again at a later date!
him............................![]()
thanks....
No problem![]()
You cannot have IE6 and IE7 on the same machine unless you download Microsofts Virtual PC.
Their reason for this I believe is both browsers use the same underpinning with files and would conflict.
