Official Screenshot Thread
everything maxed, 16x aa and bloom ( it wont let me check HDR with aa on )
same setting on both screenies is just that i'm running a news reader in the background downloading jack :)
it seems to be that FRAPS capped at 60fps or something lol.
I was asking cuz i plan on buying the game to play whit my 8800Gtx.
Can u tell us if it's running better on Vista than Xp too. Vista is another thing i plan to buy! :)
was on vista and was using forceware unofficial drivers
i'll try it on the fresh install of xp again and see what happens.
Thats so obvious then!
Right now Vista is not the best OS to run games on. It would explain why you were only getting 39fps, and why you cant run HDR and AA.
Dude, just install XP again.
still, in all reality, the human eye can only percieve 25 fps, but if it was in a calm area, it might get choppy during action. I know my pc did when playing oblivion (no surprise though, look at the specs, it was on my desktop). Anyway, I would put a hold on vista until they put a cap on all the undiscovered problems. at least wait until you can play crysis on dx10:)
Everytime someone says this, I swear it gets lower. It started out with "the human eye can only see 40fps", and now it's down to 25...
Movies play at 29.997FPS, and thats doable because each frame is blurred. Games however have a perfectly still frame, so ~30fps looks laggy compared to movies. I can easily see a difference between 30fps, 50fps, and 100fps.
actually the same thing happened when i ran this on xp sp2 :)
whats this?? i thought 8800's fixed that problem?
omega the only reason you can see the difference between 50fps and 100fps is because of speed lol... i mean i get like 300fps playing halo and i get slaughtered by the enemy @ easy settings... but if i turn on vsync it gives me time to think and aim and kill them easier.. as far as how smooth it is, i doubt 50fps LOOKS much different from 100fps lol...
[-0MEGA-];562329 said:
It can, I ran AA 4x (6x actually is worse with the G80), and HDR in many games.
Kof, are you using the forceware drivers or the official ones from nVidia?
xp i'm using the official
vista i'm using the forceware
same problem.
ever tried forcing AA with the drivers, and put on HDR in the game?
(Imo, Oblivion looks much better with HDR instead of AA tough, that is, if you have to choose between the 2.)
Thats really weird. The only thing I can think of is that Oblivion has it set so nVidia cards in general cant run both, because the G80 is capable of it. Try turning it on in other games and see what happens.
i dont see the difference between the two
theres no option for hdr on the other games. maybe only newer games have it?
maybe i can try force it because right now it is application controlled.
8800 can do both HDR and AA at the same time in oblivion, you just need to run HDR in the games option area and enable AA in the NVIDIA control panel
