keep in mind if you edit your seem (firmware) and the phone dies on you for some reason, and you're unable to get the original seem back on it, you wont be covered by any type of warranty you have on the phone
and if you mess up the seem edit, it can ruin the phone irreversibly, so follow the instructions carefully
i had to do the same thing on my e815 that i got from verizon to change it to a full fledged e815m before i could do anything but edit my contacts list through my computer
bluetooth or usb cable
^i forgot to mention, thats thru the usb cable.u can, but which model are u talkin about? im assuming the v3m. inorder to access ur computer, the only program to use is Motorola phone tools. now if u want that option to be available to use with that phone, then ur gonna have to do a seem edit because verizon did not already enable it.
It has bluetooth but I have never used it.
I can plug it in with a usb but nothing happens.
Obviously I don't know anything about bluetooth since I have never used it.
Think I'll just use my hammer for access!
