Widescreen mointors
murdock22
when playing a .avi widescreen movie is there still the black bars on the top and bottom? or does it take up the full screen.
yes, there's still black bars
16:9 can be stretched to 16:10 without being noticeable, tho
you do know that 16:10 is squarer than 16:9
it all depends on the aspect ratio that the .avi file is set to
if its higher than 1.77:1 than you will have black bars
exquisite math skills
when watching a 16:9 movie on a 1680x1250 monitor, there are slim black bars on the top and bottom
and like i said, the difference is small enough not to notice any stretching if you simply scale the image to fit
