Hi guys I have here a question that you guys should easily be able to fix.
I have only one account on my PC and everytime I start, the 'account' selection screen comes up. How can I default it to run only one account all the time?
click start>run> and then type "msconfig" and then select "boot.ini" then select check all boot paths. It should tell you that a path is no longer valid and ask to delete. select yes and voila!
Cheers
EDIT: whoops, I read that totally wrong! click start>control panel and then look for user accounts once inside click on the user that you wish to delete and some options will appear, select delete and that should do it.
No that didnt do the trick. There is still one account and it shows up in the account selection and I have to click it. Please anyone have an idea on how to fix this?
