PC Hobbyist
This is an FYI post. I can't believe I did not know this. It is soooo simple and obvious and yet I always thought you could not rename multiple files in windows explorer. Man, I feel dumb.
Is there anyone else out there like me, who didn't know this?
If so, here is how: (pasted from the microsoft site).
How to Rename Multiple Files with Windows Explorer
1. Select multiple files in a folder. To do so, press and hold down the CTRL key while you are clicking files.
2. After you select the files, press F2.
3. Type the new name, and then press ENTER.
NOTE: When you complete the preceding steps, the highlighted state of all files except one disappears, so it may appear as if you are only renaming one file. However, after you press ENTER, all of the files are renamed. When you rename multiple files, all of the renamed files have the same name with a number in parentheses appended to the name to make the new file name unique. For example, if you type BUDGET as the new name, the first file is named BUDGET. All of the remaining selected files are named BUDGET(x), where x is a unique number, starting with (1).
