Supposedly the 2mb ones overclock higher, maybe not in max speed, but the amount they overclock.
They may seem like they overclock higher because they have lower stock clocks as well. The only 2MB versions are the E6300 and E6400, as well as the newer E4xxx series. And they dont overclock higher then say, the E6600 or E6700, but when you compare it to the stock speeds, there is more of a gain on the lower-end models.Supposedly the 2mb ones overclock higher, maybe not in max speed, but the amount they overclock.
[-0MEGA-];587384 said:They may seem like they overclock higher because they have lower stock clocks as well. The only 2MB versions are the E6300 and E6400, as well as the newer E4xxx series. And they dont overclock higher then say, the E6600 or E6700, but when you compare it to the stock speeds, there is more of a gain on the lower-end models.
But again, its not because of the cache.
i heard the e6300, e6400 actually have 4 in cache, however 2 are disabled, whereas the E4*** models, being allensdale only actually have 2 built in. I've heard the E4300 can be extremely overclocked up to the level where it is faster that the X6800, HERE, and its only going to cost in the low $100's
so does anyone make any sort of verdict as to which of c2d processors are actually the best bargain for the money out there?
When you use the term "Allendale", which processors are you referring to? The E6300 and E6400 are both Conroe's.![]()
[-0MEGA-];588197 said:I bet everyone would agree with me that the Core 2 Duo's are the best processors around for the price.
Jet answered my question right...i know the c2d's are the best processor around, but i was wondering which of the series is best for its price tag.
[-0MEGA-];588632 said:Sorry, read your question wrong.
If you dont plan to overclock, I would say the E6300 would be the best because of the faster bus. But if you do plan to overclock, the E4300 may yield a bit higher potential.
the benchmarks i've seen of the e4300 have shown that the e4300 and e6300 perform almost identically, even considering the difference in the fsb. the e6320 may outperform the e4300 more substantially once you factor in the 2mb l2 cache difference though.
i probably will OC, but within some stipulations. i still think someone needs to OC the e4300 and determine a relatively stable point. i am not going to be the extreme OC'er, but would like to OC to a state where i can leave my computer on all the time and feel pretty confident my processor will last me, in that OC'd state, for a solid 3-4 years. if i can't do that, i may as well go for the e6600 and not OC it until it becomes severely outdated (since i know it OCs so well).
Both the e4300 and the e6300 ahve 2mb L2 cache...
The e4300 would be easier to overclock in my opinion, because of the higher multiplier.
If you aren't that confident in your overclocking capability, why not buy a processor that already performs where you want it to for just a little extra?
If you buy a 4300 and overclock it and it somehow gets fried or you fry something else, you're going to end up spending more money and downtime then you would if you had just spent the extra hundred or so in the first place.
From what I'm reading here, it looks as though you're not confident enough to risk it but yet you don't have the money to buy the performance that you want. Then save up a little extra or wait until early-mid may to buy what you want(better yet, save up while waiting until May).
