Pc_Pimp New Member Feb 20, 2007 #1 Anyone who has the gigabyte ga-965g-ds3 or the gigabyte ga-965p-ds3. What temps does it run at for you? When i play a game for a while and then check my board temp its at 44-45°C. Just trying to see if thats normal or not.
Rambo New Member Feb 20, 2007 #3 What is the temperature of it when idling (so, after 30 minutes of web-browsing or something...)?
C ChrisFace New Member Feb 20, 2007 #4 mine averages 39C, but that's because i set my case fans at a lower speed for the sake of being quiet.
Rambo New Member Feb 21, 2007 #6 I think they're ok. They could be a little lower, but it's still not that high. You'll be fine with those temperatures.
Pc_Pimp New Member Feb 21, 2007 #7 Rambo said: What is the temperature of it when idling (so, after 30 minutes of web-browsing or something...)? Click to expand... I believe its like 39-40°C at idle most of the time.
Rambo New Member Feb 21, 2007 #8 Pc_Pimp said: I believe its like 39-40°C at idle most of the time. Click to expand... Yeah, that's about right. I think your temps are fine. They're only 4 or 5 degrees higher than mine. Nothing to worry about.
C ChrisFace New Member Feb 21, 2007 #9 Mine averages around 35C, then again I have a huge Antec case and big fans in there.
