I have 2 hard drives. One is 80gb and the other is 400gb. I have windows installed on my 80gb and wanted to put it on my other one instead. So I unplugged my 80gb and left the 400gb in and started installing windows. Everything was going fine and got through format and loading files, then goes to reboot and I get that message right after Verifying DMI Data Pool or whatever, then I can do nothing. I can still boot XP from my 80gb drive, but only when the other when isn't plugged in. If it is plugged in then I get the message. They used to work together perfectly. I did a little bit of Google research, and it seems like I might have to clear my Master Boot Record (I don't know what that is or how to find it, or how to clear it) but my guess is when i have the 400gb in and try to boot it looks for the 80gb, and when they're both in it doesn't know what to do. How can I fix this? I went through my BIOS and set the boot priorities to the hard drive. Thanks
Jeff
Jeff
