New to building. Take a look at this set up pls :)
If you live in the US I recommend using newegg.com, they usually have good deals on hardware.
Id go with a C2D if you have the money, but if not that processor should work well as well as the other parts you have, though if you have the extra money get a 7900gs or wait till the 8600 cards come out, which apparently should be soon.
btw whats your budget?
im living in ireland so id have to search uk sites for a good deal id say. irish sites are way overpriced. i worked out for that system above an estimate of around 770 Euro ex. postage.
well i suppose i could strech my budget to around 1000 just about. im sure i could get a better set up for that. i just havent a clue what id be looking for really.
C2D and 7900gs means nothing to me. :( as i said its my first build. though i do want something decent for the money.
the c2d is one of intels best I like amd myself no offence to anyone but I've heard the c2d are very good if your going with amd may I sugest the msi diamond I use that board and I love it
heres what there talking about
http://www.ebuyer.com/UK/product/121407/rb/25743418187 -c2d
http://www.ebuyer.com/UK/product/125739- the motherboard i believe there refering to sorry if im wrong
http://www.ebuyer.com/UK/product/66382- and heres an example of ddr2
the amd one looks good just throwing out some ideas
hope it goes well if you have any question on assembling it just come on back
How does this sound then?
Processor - Intel Core 2 Duo E4300 1.8GHz Socket LGA775
http://www.komplett.ie/k/ki.asp?sku=330167 E165
Video / Graphics Card - GeForce 7900 GS
http://www.ebuyer.com/UK/product/125107 E161
Memory - Corsair 1GB Kit
2x http://www.ebuyer.com/UK/product/66382- E148
Dvd/cd rw - LG GSA-H42NBAL 18x DVD±RW
http://www.ebuyer.com/UK/product/124905/rb/25739750465 E29
Motherboard - Foxconn 975X7AB Conroe motherboard
http://tinyurl.com/2wv9uw E170
Case - SopranoVB1000BNS
http://tinyurl.com/274lt9 E64
Psu - Sweex 650 Watt gold power supply
http://tinyurl.com/ypaulh E59
Hard drive - Seagate Barracuda 7200.10 320GB
http://www.komplett.ie/k/ki.asp?sku=320713 E90
total: E886
