Laptop
Hello gusy, I just found this laptop perfect. But dont have the budjet or plan to buy this. But one of you may find this useful.
I Just copy and pasted this into here. so just ingore, if you found any mistake and ask for the help if u dont understand anything ( I mean any writing problem, not technical
Intel® Pentium® Dual-Core Processor T2060 1.60GHz 533 MHz FSB 1MB L2 Cache
What is Dual Core?
Two processor cores work within the same processor to increase the performance of your PC. Dual core technology means that several demanding applications can be run at the same time, allowing your computer to think as fast as you can multi-task.
Intel® Graphics Media Accelerator 950 PCI-Express technology
Based on PCI-Express technology, 128MB shared memory.
15.4" TFT WXGA Widescreen Display
1280 × 800 pixels. 16:10 widescreen cinema format for optimized DVD playback and usability.
1,024MB DDR2 SDRAM
High performance for all multimedia applications.
120GB Hard Disk
Space for up to 25,000 digital photos or 25,000 MP3 tracks (at 4MB per track).
8 × Multi-standard DVD/CD Burner with DVD-RAM and Dual Layer support
Watch DVDs and make your own. Reads and writes: DVD±R/±RW/±R DL/DVD-RAM/CD-RW/DVD-ROM.
Wireless LAN 802.11 b/g
Connect to the internet without plugs or cables with Wireless LAN technology. Data transfer speeds up to 54Mbit/s (requires WLAN access point).
6-channel audio out (analogue + S/P-DIF)
Enjoy amazing “home cinema” surround sound with 6 channel audio out (use in conjunction with a compatible surround sound speaker system).
A world of television
Includes a DVB-T TV tuner card with telescopic aerial attachment.
4-in-1 memory card reader
2 multimedia speakers
What is Dual Core?
1,024MB DDR2 SDRAM
120GB Hard Disk
