Building a computer
Risingtide93
I'm about to build a computer but I'm not sure if it is going to be good gaming/entertainment computer...:confused:
Can someone tell me how good it would be? :confused:
Parts:
Case: X-Cruiser Mid-Tower 420W Case W/ WINDOW, MultiMeter Display & Control (Black)
PSU: LOGISYS Computer PS550ABK 550Watts Power Supply With SATA and 20/24 Pin connectors.
CPU: Intel® Core™ 2 Duo E6400 CPU @ 2.13GHz 1066FSB 2x1MB L2 Cache EM64T, INTEL LGA775 CERTIFIED CPU FAN & HEATSINK
Motherboard:Asus P5N-E nForce 650i SLI Chipset LGA775 FSB1333 DDR2 Mainboard
RAM: Four Corsair 512MB PC2-6400 DDR2 DIMM Memory Kit (Total 2GB)
Video Card: eVGA eGeForce 7600 GS 256MB Video Card
HD: 320GB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD
Optical Drive: 18X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER
Sound Card: 3D WAVE ON-BOARD 5.1 SOUND CARD
Speaker: Logitech S100 2.0 Stereo Speaker Set
OS: Microsoft® Windows Vista™ Ultimate
Thanks
1. get a better graphic card.
2. get 2 x 1 GB Ram instead of 4 x 512
3. Find another cheaper case without PSU. Why are you buying 2 PSU for 1 PC??
4. For your HD, don't forget to buy one with NCQ. By the way, it may run better with 2 x 160GB HD than one 320GB
5. Vista Ultimate is quite expensive, Do you really need it? Will the Home Premium be a better choice?
