All audio settings for all audio devices are, strangely enough, in the "Sounds and Audio Devices" section of Control Panel... I use a USB headset everyday for the exact same purpose you do, i only use the mic from it, i use my normal speakers for output.I went and firring bought a good old standard 1/8" connection type. Problem solved. Don't ever buy USB headsets.
