salman
Hi could you guys take a quick look at my build before I order to make sure everythings compatible and give me any advice or recommenadations before i order. Thanks.
Processor- Intel CPU Core 2 Duo E6300 1.86GHz 1066FSB LGA775 2MB cache Retail inc.Fan (3yr Manufacturers Warranty) £111.61
http://www.microdirect.co.uk/(14432)Intel-CPU-Core-2-Duo-E6300-186GHz-1066FSB.aspx
Motherboard- Abit Fatality FP-IN9-SLi Motherboard LGA775 nForce 650i SLi Intel Core 2 Duo / Quad processors ATX £69.90
http://www.microdirect.co.uk/(16724)Abit-Fatality-FPIN9SLi-Motherboard-LGA775.aspx
RAM- Geil value RAM 1GB ddr2 800mhz £51.69
http://www.microdirect.co.uk/(14772)Geil-Value-DDR2-10GB-PC6400-Dual-Channel.aspx
Hard Drive- Seagate ST3160811AS 160GB 7200.9 SATA II 7200RPM Drive – OEM £37.80
http://www.ebuyer.com/UK/product/112227
CD RW/ DVD ROM- LG CRW/DVD combi drive Beige oem £11.87
http://www.microdirect.co.uk/(12092)LG-CRWDVD-combi-drive-Beige-oem.aspx
Graphics Card- DabsValue NVIDIA GeForce 7600 GS 256MB DDR2 PCI-E DVI £54.99
http://www.dabs.com/productview.asp...1137&PageMode=1&NavigationKey=11137,380070000
