Warning: System Boot Failure
spealman
Need advice: "Warning: System Boot Failure"
Had a computer built and for some reason I get this boot error when I boot the computer up in the morning.
When I first turn it on, the computer powers up yet it wont boot. I shut it down and turn it on again and I get the following error message:
"Warning: System boot fail. Your system last boot or POST interrupted. Please enter setup to load default and reboot again."
I can ignore the error and the computer works fine but it's a pain in the butt I'd like to resolve.
This only happens when I turn it on for the first time in the morning. If I turn it off and then turn it back on, it boots properly.
I have gone into the BIOS and loaded the default set up for all setup items but I still get this same error.
There must be a simple solution. Was unable to find a thread pertaining to this. Can anybody guide me on how to resolve this issue? If there is any more info I can provide, let me know. Thanks.
Spealman
Same problem
Spealman
I have the very same problem, I have googled this to death but can't find a simple solution, the responses usually end up recommending troubleshooting hardware. I did notice that I have the same Motherboard and so did a couple other folks who have the same issue. Hope someone posts a solution.
My friend has the same board and I know he has had a few problems with it as well, but not that issue. Have you tried updating the bios? Replacing the cmos battery? Called Asus support? Tried a different power supply, just in case?
Boot failure
Thanks Johnb35, I haven't tried anything yet, I was hoping it was just a glitch that could be remedied just by changing a parameter or a setting, I will try the BIOS update and go from there.
