Is there a Software
TrakRunnaz
I was wondering if anyone knew of a software that would allow me to burn sounds on a cd from my desktop. And put the sounds on my laptop? Example. I have fruity loops on my desktop , and i want to burn different kicks , snares , and hi hats onto a cd so i can transfer them onto my laptop. I also have fruity loops on my laptop but my laptop isnt internet ready only my desktop. Any help would be greatly appreciated. Thanks
ok, u just need to know where ur sounds are then u can use program called Nero to burn it if u need further information how to do it or where the sounds are post again ( assuming u know how to do this)
Thanks for the response. Yea i know about Nero. So all i have to do is burn the sounds onto Nero on my desktop. Take that CD and load it onto my laptop? Thanks
It depends, since you're using fruity loops, you would record the sounds, then convert them to the file you would want, and then you can burn the sounds using Nero. Why do you need to transfer them to your laptop?
