CheshireCat
I'm having issues with my new XFX 7900GS.
I plugged it in, attached the 6-ping to 4-pin power adapter, plugged it into my PCIEx16 slot and attached the DVI cable from my monitor.
Then I turned the computer on and it posted fine and was running...however there is no display. If I pull the card out and hook my monitor up using the onboard VGA it works fine, but I get no display with either connection as long as the card is installed.
I can see that the fan on the card is spinning and I can hear the computer post and start normally, I just can't see anything in the display.
What sucks is that XFX doesn't include any hardware installation instructions and troubleshooting information seems to be nonexistent.
Can anyone think of anything I might have forgotten to do?
