What do you think of this?
Kornowski
I'm on a tight budget and this is the best that I could come up with at the moment, I can't wait, I think it'll be a huge step up from my current computer.
What do you think of it?
Gigabyte GA-965P-S3 - £69.91
Core 2 Duo E6300 - £111
GeForce XFX 7900GS - £109.28
Corsair XMS2 1024MB - £50.18
£340.47
I have a monitor, keyboard, mouse, speakers, HDD and PSU so they're Ok.
What do you think?
Personally. I think it's a wonderful upgrade! Not a bad price either. I'd say go for it! :D
Yeah, It'll certainly be better than what I have at the moment, although not being really bad, not being really all that good either! :P
Do you think the new one would be Ok for gaming?
I may get another 1GB to make 2GB when and if the prices of the Core 2 Duo's come down.
Well, it's definitely not a bad card. I'm sure you can play some of the newer games on some pretty decent settings. It's better than nothing! :D
Yeah, I'm hoping to play Crysis, lol :P
On maybe low - med... *fingers crossed*
Yeah, it's better than what I have now, no doubt about it! I really can't wait!
Looks good,What i would do is overclock the e6300 when you get it and maybe invest in another gig of ram at a later date.
Yeah, I think I'll OC, I just don't know how much by though, I won't be buying an aftermarked cooler yet, so...
I may get another 1GB of RAM.
Does anybody know if it'll be good for gaming?
i cant see why not, good enough card plus you should get away with overclocking a bit on the stock cooler. P.s when is crysis out (its the new far cry isnt it?)
Yeah! :D
I can't wait to build it, it'll be after the prices of the Core 2 Duo's have come down though, After April 22nd.
Looks good.. I don't think it'll handle Crysis all that well. You've seen the requirements for it, and what they've designed it for...
Yeah, I've seen the requirment, mine meets them...
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6200 or ATI X1300 - Shader Model 2.0
RAM: 768MB on Windows XP or 1GB on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7600 or ATI X1600 Pro (SM 3.0) or DX10 equivalent
RAM: 1.5GB+
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
