Share a cool case...
I used this case a little while ago to build a E6300 build for someone. Really nice looking mini tower for a great price... I would definitely use it again:
http://www.newegg.com/product/product.asp?item=N82E16811153028
The computer I'm using right now was built with this case... pretty decent, especially for the price. Has good looking lights, but the side panels are a little flimsy, and while I like the way it looks, I don't think I'll ever buy a case with a door covering the 5.25" expansion bays... to easy to break off if your not pay attention:
http://www.shopping.com/xPO-Power-U...ith-Perforated-Side-Front-USB-and-Audio-Ports
i use an antec p180b, and think it's pretty boring, but very understated and nice looking
it "looks" fast :) cause it's all business, and no bs
but i wont lie..... i'd kill a man in front of his own mother for a silverstone tj07
i think that's hands down the nicest looking case on the face of the earth.
stock photos don't do it justice, you gotta see it loaded in person. It's an amazing case.
I was looking at that case burgerbob, the one you have. What size fans does it use?
80mm, which kinda sucks, and you have to take the entire case apart to change stuff, but NO ONE has a case like it. It really rules with cold cathodes and lots of LEDs. I love it to no end, i can see all my components all the time.
Edit: and with the right fans and whatnot, airflow is great and my temps are great. Also, it doesnt vibrate like an aluminum.
There is one on oxiode.com (<~~sp?) that is similar. It has 4 or 5 80mm fans with it and you can select the fan color and everything for a lot cheaper than the price of that one. A buddy of mine also bought a similar one and it cost him $150ish.
Well, in any case (pun intended) get a clear acrylic. They are awesome.
