How to destroy a hard drive physically
If you know someone with a welder get him to strike an arc on the case, 50 volts at about 300 amps will create enough of an electromagnetic field to fry any HDD
The best options are to use a strong magnetic field to wipe the date, or to melt the platters (if you have access to high enough temperatures).
Hook up jumper cables to your car battery and touch both ends to the drive, that will (0) the thing out;) . No dont do that really, if it blew up or you got hurt it would be my fault!
I'd say an electric sander on the platters would be practical (but nothing is more practical than a hammer :P)
