ferrisbueller
I recently found some free software that is a PC Diagnostics tool. It identifies the precise problems in your Windows registry so you can determine exactly what your PC is suffering from.
Even if your PC is perfectly fine, you should try the diagnostics tool if you want to avoid serious problems before they happen. Best of all you can keep the tool and find out if your PC has problems for FREE as often as you like.
It can be found at :
http://docburgo.errornuker.hop.clickbank.net/
