System shutdown when working. Any idea??
madcom
hi guys,
I had a compaq version year 2000. just yesdterday my laptop have problem that suddenly shutting down when i was doing my job. It happen about at least 10-15 minutes when my notebook is turn on. wheb it happen, a box at center screen appear and shown 'windows will shutdown in 60seconds, please save all ur works that running' sothing like that happen then it will shutdown. when i turn it on again, it happen again. i try to restart n turn back, but it still like that. I got many assingment that have to settle.
for ur guys information, this is not a first time happen, before this, about 3 month ago it happen then i format n reistall windows back. but now it happen again. so what exactly the problem is???:confused:
notebook,
pentium-3 985mhz
128mb ram
30gb hdd
running windows xp sp2
please!!!... can this problem solve???
a long time ago there was a patch released to cover that hole in windows. What is happening is a piece of software (virus worm mal ware) something is exploiting the remote procedure command to shut down your computer. The reason reinstalling windows worked was because it removed what ever was exploiting this hole. What you'll have to do is remove what ever is activating that command then you'll need to install the patch so it can't happen again.
http://www.faqs.org/rfcs/rfc1831.html
And use Firefox !
Rules of the game, update to SP2 (Service Pack 2) use Firefox, Ad-Aware, Spybot, and Defender for spyware protection. Most importantly, have an AntiVirus software in your computer!
These are basic requirements to prevent such headaches for you.
Re-install Windows, download and install Service Pack 2 and then apply all the other applications I mentioned above to secure a safe operation of your computer.
Good luck!
you wouldn't have to reinstall windows, in addition for some people that isn't an option. You could also use Opera web browser
http://www.opera.com/
it's just as nice as fire fox and even fewer people use it.
Try one of those removal tool before you go reinstalling windows.
