I have a Belkin F5D5231-4 router.
The troubles I am having with it regards port forwarding; I'm trying to get a game working, and nothing I try has any effect at all on the end result.
I tried fiddling around with the settings, and using Shields UP!! to test my system, but the results confuse me completely.
Router Default Settings : All ports stealthed bar port 515
Router instructed to make my IP a DMZ - excluded from firewall : Most ports closed, 5 or 6 ports open.
Router at default, instructed to open certain ports : All stealthed bar port 515
Router DMZd, instructed to open certain ports : Most ports closed, 5 or 6 ports open.
However I instruct it to open particular ports, it doesn't seem to heed me.
UPnP also doesn't have any effect on the game itself, I always get the same error message - 'connectivity issues'.
For the record, my internet works perfectly browsing the web.
